Super H grille
ellson
07-11-2003 15:02:41
I am looking unsuccesfully for a grille for a Super H (Stage I) Is a regular H grille the same except for the holes where the aluminum Farmall emblem bolts on the front
Pat H
07-12-2003 12:17:18
 Re: Super H grille in reply to ellson, 07-11-2003 15:02:41
A regular H grill will be the same as a stage 1 except as you said where the farmall emblem is instead of the square IH emblem. Please consider adding your Super H to the serial number registry if you haven't already done so. Best of luck finding a good grill. Try watching ebay-- sometimes reasonable prices and sometimes not. Pat in Wisc
CNKS
07-11-2003 19:35:20
I think the H one will fit, but the Super H grille has two holes on either side near the top that the H grille doesn't have. I'm also not absolutely positive about the fit with the radiator. Give Mike Bunck at Steel Wheel Ranch a call. 785-548-7437. Also Abilene Machine at 800-255-0337. Call Mike first, Abilene Machine won't know until someone goes and looks, Mike will give you an instant answer, condition, and price.
