Generator Oopsiedasies
BamaScot
07-11-2003 18:33:40
Doggoneit!!!!! The old generator on the '48 M doesn't want to get up in the morning anymore. As a temporary (I do mean temporary!!!), can I use the 12v generator off the 504 I've got sitting out back. She's waiting for me to get off my duff and do a total makeover (like the ones they show on that E channel) This will give me enough time to get the one on the M rebuilt. I will still run the 6V regulator ( since it's new anyway). I'll put an extra coat of clearcoat on the 504 if it will work?
CNKS
07-11-2003 19:26:48
 Re: Generator Oopsiedasies in reply to BamaScot, 07-11-2003 18:33:40
I think, "here try this" is right, but does you M have a mag? I don't think IH had gotten around to putting distributers on everything in 1948. If so your generator has a cutout relay, not a voltage regulator, so I don't think it will work. If it does have a mag, disconnect your non-working generator and cutout and crank it, or use another 6 or 12 volt battery to start it. A good battery will start your M many times before you have to recharge.
BamaScot
07-12-2003 15:15:28
 Re: Re: Generator Oopsiedasies in reply to CNKS, 07-11-2003 19:26:48
Regulator not cutout, distributer not mag.
CNKS
07-12-2003 19:00:47
 Re: Re: Re: Generator Oopsiedasies in reply to BamaScot, 07-12-2003 15:15:28
In that case take your generator AND voltage regulator to an electrical shop and have it (them) repaired. Probably cost you less than $100.
CNKS
07-12-2003 19:04:01
 Re: Re: Re: Re: Generator Oopsiedasies in reply to CNKS, 07-12-2003 19:00:47
I forgot that your regulator was new. But, the local place wants both of them anyway so both can be adjusted to work properly.
here, try this
07-11-2003 18:36:36
i think you will burn up your new regulater.
