Tuning a Super M carb
Kiwi BM
07-12-2003 03:57:23
Can anyone tell me please the simple way of tuning a Super M carburettor?
Has been sitting idle for a few months as we do up the clutch and a few other jobs. Engine runs okay, but we cannot seem to slow the idle right down. Is there a correct tuning procedure we should be aware of?
CNKS
07-12-2003 18:54:36
 Re: Tuning a Super M carb in reply to Kiwi BM, 07-12-2003 03:57:23
If you had the carb off be sure that the throttle shaft inside the tube that runs between the governor and the carb is installed correctly. The end of the throttle shaft in the tube fits into a notch on the carb throttle shaft.
rustyfarmall
07-12-2003 06:13:27
The problem may be in your governor, or in the throttle linkage, try backing out the idle speed screw on the carb., if it doesn't slow down, then you need to look somewhere besides the carb.
Kiwi BM
07-12-2003 13:04:31
 Re: Re: Tuning a Super M carb in reply to rustyfarmall, 07-12-2003 06:13:27
Many thanks Rusty, we think we may have to overall the governor, and you just confirmed we have more work to do.
