140 cultivators
Kevin Emig
07-12-2003 20:27:07
I just bought a set of front and rear cultivators for my 140. It was originally a county maintenance tractor using a sicle bar, and I am now using it for a garden tractor. My question is , where do I find a site that shows a 140 with the cultivators on? I have some spring rods that I think are supposed to be verticle tension rods for floating the cultivator blades, but I'm not sure. They look like they in turn get attached to a horizontal rod, since they have the same size rings. Am I right? I'm also not sure if I have all of the rods I need. I'd appreciate any help.
Hugh MacKay
07-13-2003 06:16:51
 Re: 140 cultivators in reply to Kevin Emig, 07-12-2003 20:27:07
Kevin : Chris has the best long term solution. If you want to take the time the photo gallery has some decent photos of SA, 100, 130 and 140 with front and rear cultivators mounted. Also a few in photo adds in past two weeks. You may see some differences from what you have as there were many variations in these units depending what they were using them for. Basically the same 144 cultivator was used on all 4 tractors. The unit on the A was different.
If you wanted you could e mail me as I have some shots of my tractors, only thing is I have made so many modifications over the years it probably would confuse more than help. I have converted my cultivators to all modern ground working tools, S tines, V hoes, and yes even no till equipment. I now till my garden up in fall and make hills or rows. A nice crop of weeds come in fall and frost gets them. In spring I very slightly till tops of hill or rows with no till coulters and plant. Since I don't disturb soil in spring my weed seeds near enough surface have all germinated in fall. If you are far enough south you may need a bit of Roundup to do what frost does for me.
These days most of my spring tillage is being done on next years garden which I plant in buckwheat to plow down end of Aug before it goes to seed. This system has not completely eliminated hand weeding, but it sure has cut down on the need for it. The only in row cultivation I have done this year is on potatoes and I have some very sharp sweeps that I just skim the surface between rows for emerging weeds, I don't disturb soil just shear weeds at surface.
chris va
07-13-2003 03:35:12
I've had good luck going to the case dealers that were IH dealers and asking the parts guys to photo copy the pictures in the front of the parts manuals, so far they always have, but they know there's usually a part I don't have and will come back to buy it. Hope that helps!
