Switching from cutout to regulator on A Farmall
Terry
07-13-2003 19:40:22
Does anyone know if I can install a regulator in place of the cutout. I would like to be able to put the regulator on top of the generator like the original cutout is mounted.
Can this be done, and what regulator would I use.
In order for me to be a complete pain in the rear, I will need a wiring diagram also!!
thanks for your help
Haas
07-14-2003 05:17:26
 Re: switching from cutout to regulator on A Farmal in reply to Terry, 07-13-2003 19:40:22
Switching from the cutout relay to a regulator is easy to do. Regulators are available from a number of after market sources, already equipped with the mounting bracket to mount on the generator. Go to E bay and look up the seller "mister_ih". He has them. If none on E bay, send him a question.
krr
07-13-2003 22:27:38
you can get a regulator from napa auto parts try a vr850 or vr851 it should come with wiring instructions..... .
