M Service Question (oil)
Big Red
07-13-2003 19:50:39
I was wondering how many quarts of oil the M engine took?? Also where is the best place to find a new oil filter? Do any of you guys know where a good place is to find an air filter for one too? Thanks for the help!
Dan
07-14-2003 12:12:25
 Re: M Service Question (oil) in reply to Big Red, 07-13-2003 19:50:39
One more point, there are two different filters used on these. You might want to take yours along when you go to get one. I got the wrong one from IH. Don't think it goes by sn
Wayne Swenson
07-13-2003 20:44:54
See your friendly Case-IH dealer or NAPA store for the filter, make sure to get the new square-cut sealing ring with the filter. Be sure to dig the old one out and carefully clean the groove before installing the new seal ring.
You will need about 8 quarts to fill the crankcase, filter, & oil bath air cleaner.
Get a 12 pack of good detergent oil 30 weight for summer and you will do just fine plus there is some extra oil in case the engine uses a little.
Don LC
07-13-2003 20:42:12
8qt.----manual says -- above 80* = SAE 30 32* to 80*= SAE 20 below 32* SAE 10.....If you are playing with it I run SAE 20 year around.....You need a operators manual & service manual----- Binder Books (503)684-2024
Jimmy King
07-13-2003 20:54:03
 Re: Re: M Service Question (oil) in reply to Don LC, 07-13-2003 20:42:12
Well I said off the top of my head and it must have been in a dark place when I the read the question.
Jimmy King
07-13-2003 20:31:42
Off the top of my head with filter five I think. If you want a oil bath salvage yard, for dry filter????? ??
