IHC plows
Farm w/Junk
07-13-2003 21:42:50
Hi I have three IHC plows. One is on steel and a three bottom clutch lift. The other two are 2 bottoms on rubber and clutch lift. One just uses a pin to hitch it and the other has the spring hook for a clevis. Is the hitch for just a bolt original? How can I find out what models they are and how can I tell on others? Where can you get the 3.50x12 tires on the back? Are these plows worth much? What years were they made? The one has canada stamped in the beam the othesr dont. What this mean? Thanks a lot.
Matt
Hugh MacKay
07-14-2003 13:39:57
 Re: IHC plows in reply to Farm w/Junk, 07-13-2003 21:42:50
Matt: Which plows have the trip hitch? Whitch plow is stamped Canada? Does the plow with pin hitch have trip bottoms? If the plow with pin hitch has trip bottome it most likely a Model No.60. Do any of these plows have cranks in place of levers for depth and levelling? Take each plow separately and go to details of each. Right now you are not being very clear and concise on each. Let us know which specifics belong to each plow, and lets call them plow 1, 2 and 3. We can nail them one plow at a time. They may all be same model and they may all be different models.
Farm w/Junk
07-14-2003 18:58:47
 Re: Re: IHC plows in reply to Hugh MacKay, 07-14-2003 13:39:57
Hi the first plow is a three bottom on steel with the spring hitch for a clevis. It has levers for depth. It is a clutch lift. It looks like it has an add on bottom. The second is a two bottom on rubber with hitch for a clevis. It has levers for depth. It is a clutch lift. It has canada stamped in the beam next to the trip lever. It also has 16 inch rims. The third is a two bottom on rubber with a hitch that uses a regular pin. It has levers for depth. It is clutch lift. It also has 15 inch rims. Were the three bottom plows just two bottom plows with an add on bottom? Thanks a lot.
Matt
