Carb iceing up
Matt
07-14-2003 06:04:14
The manifold and carb are very cold and icing up on my tractor the carb is the up draft type.The tractor seems to start and run ok. What could be causing this. Thank you.
Aces
07-14-2003 13:15:53
 Re: Carb iceing up in reply to Matt, 07-14-2003 06:04:14
What tractor do you have the 6 cylinders have heat rizer in manifold.
grg f20 from WI
07-14-2003 06:52:23
The reason is the reduction of pressure which lowwers the temperature of the incoming air. The ice forms because of the cold temp and high outside humidity. Most cars have carberator heat tube to eliminate this problem, tractors do not.
Airplanes have this problem also and if not reconised will cause the engine to die, the have carb. heat to help prevent this, but reduces power.
