Mounting one-piece wheel weights on an M
Lowell Davis
07-15-2003 08:24:20
Hello -
Anybody have a suggestion for mounting one-piece wheel weights on a Farmall M?
Holding the 145-lb weight in one hand while reaching around the tire to insert the bolts just doesn't sound promising, and I don't think I'll be able to enlist too much help from family members!
The wheels are on the tractor dished in towards the driver's seat.
Thanks!
CNKS
07-16-2003 19:18:33
 Re: Mounting one-piece wheel weights on an M in reply to Lowell Davis, 07-15-2003 08:24:20
If you do much work on these things, and work by yourself as I do and don't want your wife to find you dead sometime -- get an engine hoist -- good for many things. A weight won't kill you, but if you ever remove a wheel---.
Harold Hubbard
07-15-2003 19:42:01
Not trying to be wise or anything, but if you have a forklift available, the forks fit right into those notches on the outside of the weight.
Jim
07-15-2003 14:16:37
Pretty simple with about 2 foot long ready bolt and a couple of nuts and washers. Roll the weight to the tire. Boost it so the ready bolt goes through the lowest hole on the hub and the top hole on the weight. Put on the washers and nuts. Lift and turn the weight 180 degrees and attach the top bolt. Remove the ready bolt and replace with the final bolt. Does not require much lifting and holding. I am 62 and do them by myself. My 2 cents.
Aces
07-15-2003 10:10:48
IHMan is right just use allthread or the bolts with thread clear to the head put jam nut on to hold bolt pich up weight and put it on did this many times.
John J
07-15-2003 09:34:45
I change mine on my H, with 13.6 rubber, by taking a bale of hay, or straw, and taking a piece of 2 x 4, laying the 2 x 4 on the bale, thru the slot in the wheel, slide the weight on the 2 x 4, up to the wheel center, put the bolts in. I have done it this way for 33 years with good results, and no mashed toes, or fingers.
Bob M
07-15-2003 09:09:34
Lowell - That's a tough job to do solo! If possible I utilize the services of my 25 year old son for stuff like that. However I've installed/removed them several times on my SH and SM (wheels set dish facing out) by myself. Here's how I do it:
1 - Put on your steel-toed boots, then park your tractor on soft grass and (safety first!) Stop the tractor so one of the weight mounting holes in the wheel is at 12 o'clock.
2 - Roll the weight next to the tire and orient the weight so the two flat edges in the weight's center opening are at the top and bottom. Now lift the weight and set it temporarily on the axle.
3 - Take one of the weight mounting bolts and insert it thru the top bolt hole in the weight. Then jam a soft wood chip, piece of foam packing or similar between the bolt and the hole in the weight to temporarily hold the bolt in the hole (to keep the bolt from getting pushed out in the next step)
4 - Now comes the hard part! Hike the weight up off the axle, align the bolt with the hole in the wheel, then slide it in to the wheel as far as you can. If you do it right and don't push the bolt out, there will now be enough thread showing on the backside of the wheel to catch a nut. But don't tighten the nut yet...
5 - Rock the weight back and forth as required to align the wheel and weight holes, then insert the other 3 bolts.
6 - Finally thread the other nuts on and tighten them all down. (Don't know if this is "correct" but I use lockwashers under the bolts)
Since your wheels are set dish facing in, mounting the weights may be easier. May be able to get them into position by lifting with a loader, come along, etc. and avoid the manual lifting like I must do.
Good luck (and watch your back!)
Randy in NE
07-15-2003 08:41:33
It only takes a second person a minute to hold the bolt while somebody lifts the weight into position. Do the top one first and then the weight of the weight will hold it in place. Start the nut. You can then move the weight as necessary to get the other bolts started. I was able to wedge a short screwdriver in behind the head of the bolt but you still need to be careful so that you don't knock the bolt back out. You can also use a piece of threaded redi-rod and put a nut on both sides of the rims. Then you can remove the redi-rod once you get a couple of other bolts started. Be sure to have the weight turned the right way so that you can get to the bolts on the axle hub. You will notice that the center of the weight is oval shaped. The long end of the oval should be aligned so the it is in the same direction as the axle bolts.
IH Man
07-15-2003 10:02:56
 Re: Re: Mounting one-piece wheel weights on an M in reply to Randy in NE, 07-15-2003 08:41:33
Get some 3/4" or 1" threaded rod about 6" long and double nut it through the rim holes. pickup the weight and slide it on the threaded rod, install washer and nut and away you go..simple procedure..... ..... .
