Farmall 400
what equipment can I use
Paul
07-15-2003 15:15:44
I have a Farmall 400. I want to bale some hay for my horses. What type of mower, baler, etc can I use with the 400?
K.B.
07-15-2003 16:08:32
 Re: Farmall 400 - what equipment can I use in reply to Paul, 07-15-2003 15:15:44
You should be able to handle most small square balers with no problem. 7' haybine would be no problem, could probably run a 9' haybine.
TP from Central PA
07-15-2003 18:38:46
 Re: Re: Farmall 400 - what equipment can I use in reply to K.B., 07-15-2003 16:08:32
It should handle any haybine in either a 7 or 9 ft'er..... .....Here's what I would buy..... .
1. NH 269 Baler
2. NI 404 Wheel Rake(Good for horse hay, can go fast)
3. NH 489 9ft'er
Their ya go..... .Simple list huh? ;-P Oh, forgot your wagons!
Tim Nichols
07-18-2003 19:32:01
 Re: Re: Re: Farmall 400 - what equipment can I use in reply to TP from Central PA, 07-15-2003 18:38:46
FYI
I use a NH489 Haybine, Ferguson 3pt hitch rake and JD 14T baler with no problems.
