PERFECT PAINT JOB
HANK
07-15-2003 15:19:16
PERFECTIONEST BUDDY AND I TOOK HIS FARMALL C DOWN TO BARE METAL AND UNDERCOATED WITH WHITE SPATZ. NOW HAVE IH PAINT AND PROFESSIONAL WET LOOD HARDNER READY TO PAINT. QUESTION IS HOW LONG SHOULD WE LET THE HARDEND
PAINT DRY BETWEEN COATS? HE WANTS TO PUT ON TWO COATS BEFORE WE RE-ASSEMBLE AND A THIRD AFTER SHE IS ALL TOGETHER
WHICH SUITS ME, BUT WHATS THE PROPER TIME FOR THIS
STUFF TO SET UP?
Don LC
07-15-2003 22:09:32
 Re: PERFECT PAINT JOB in reply to HANK, 07-15-2003 15:19:16
Hank,
I generally start by hitting the hard to get places first with the hood and grill off.....then paint the under side of hood and grill...carefuly install these parts.....might want to paint the gas tank while it is off...now start with a sticky coat....about 60--70% coverage...over the entire tractor ....then start right back over with a wet coat( slower = more paint)...run your gun across the top...up and down on the sides(get hard to get places first) ...wait about 20 - 30 min.(paint still sticky but stable)...now add your second coat same as last, except now run your gun front to back ....you are crossing first coat strokes 90*be careful this is your last coat..... .lay it on like you were using a brush..... I hope this helps.....Don
REDMAN
07-15-2003 21:59:54
when ever we paint it is usually about an hour,but the more you put in the slower it will dry,i'd talk to where ever you got the paint and find out for sure.hope that helps
Peabody
07-15-2003 18:37:59
I can't answer your question, but that ought to be one good-looking C when you are through. Make sure you post some pictures.
