656 Hydro lunging
smirkey
07-16-2003 07:54:12
yesterday while cutting hay the hydro speed contol started acting up. from the neutral position, as you pushed the lever forward the tractor did not move for a few seconds, then suddenly lurched forward and then operated at that speed okay. but it's doing this all the time now. the oil level is good. hydro was rebuilt about 5 years ago. any suggestions where to start looking?
RayP(MI)
07-16-2003 18:55:01
 Re: 656 Hydro lunging in reply to smirkey, 07-16-2003 07:54:12
No experience with the 656 - but other hydros I have had trouble with, the most common problem was low fluid, or filter plugged - both easy and cheap to check & replace.
Aces
07-16-2003 14:20:35
Smirkey I would you have a valve that is not working just right could be deceleration valve or maybe servo valve, but I would get it check out.
SuperCmore
07-16-2003 13:42:24
A little off the subject, but what would happen to my (oh no) John Deere Garden Tractor if I put 80 or 90 weight in it's slipping Hydrostatic Transmission?? Would it quiet it down and work better?? Thanks, Cmore
kjm
07-16-2003 20:58:46
 Re: Re: 656 Hydro lunging in reply to SuperCmore, 07-16-2003 13:42:24
Super c more, Since the hydro calls for JD or Type F transmission fluid( F fluid is very dry not much lubercation) it would probley quit. lol kjm
RayP(MI)
07-16-2003 18:51:48
No, you really need to put in what the manufacturer designed it for - If I remember right, Ford spec automatic transmission fluid. I did change mine out a few years back, and used GM Dextron, has worked OK. Be sure to change out the filter too!
Brian
07-16-2003 11:00:17
I worked for a farmer in highschool that had a 656 that did that exact same thing. He always swore it was a dirty filter on the hydro lines. He always had pretty good equipment that ran well, so I tend to think he knew what he was talking about. Anyway it is an easy and inexpensive place to start.
