TD 18A Crawler Engine with broken rings
MN Charlie
07-17-2003 05:49:12
Has anyone had the fun of pulling the cylinder heads off a TD-18A Crawler tractor? When I removed the first head I found pieces of broken rings on top of the pistons. Guess that's why she would not fire on No 1 cylinder. When I pulled the back head I found 2 more pistons with broken rings. Does anyone know where to start looking for parts for this engine? Some good used pistons would make it run again and a cylinder head gasket set would help. I would like to visit with somebody that has ever worked on this engine. I have a WD-6 in my tractor colection so I know the basic principle of what makes this engine Start and Run. The TD-18A is just larger, over twice the size of the WD-6. I need to take some pictures of this 6 cylinder 691 CID engine. It is huge. Thanks for the help.
Tom Graham
07-18-2003 17:54:39
 Re: TD 18A Crawler Engine with broken rings in reply to MN Charlie, 07-17-2003 05:49:12
Charlie, call Brian Guertin from LeSueur Co. Pioneer Power Dirt Gang 507-665-6158. He's in the process of rebuilding an 18 that his dad operated many years ago. He knows where to get parts, he knows about these rigs. Get yours ready to bring to the Red Power Rally at Pioneer Power Aug 22-24. Where you from?
adam o.
07-17-2003 12:20:56
hello M.N. charlie my name is adam im out in california i have a td 18a that i removed the heads off of to replace the head gaskets i found the parts i needed from FP smith inc. in sacramento ca. ph (707)864-1122 also you might take a very close look at the heads for cracks mine had cracks between the valves good luck p.s. im selling mine cheap it is currently operational but the steering clutches are stuck on right side it has a 12ft blade on it if interested feel free to contact me
justin
07-17-2003 06:27:10
I have a NOS set of pistons and sleeves, and a pair of NOS head gaskets also.. email for more info.
