farmall (a) hood attachment.
Jonathan Mirgon
07-17-2003 13:25:58
I have an (a) that I am restoring, The gas tank has the dzues fastners for the hood, and the new radiator is set up for the j-hook attachment. I plan on buying a new reproduction hood from o.e.m, But am unsure which hood to order. Any ideas on how to adapt a new hood to this set up ? should I order the dzeus fastner hood or the j- hook hood ?
thanks for any input ,
Jonathan Mirgon
justin
07-17-2003 15:39:07
 Re: farmall (a) hood attachment. in reply to Jonathan Mirgon, 07-17-2003 13:25:58
The easy way to do it is to buy a fuel tank to match the hood
LanceM
07-17-2003 15:28:14
I guess it depends how accurate you want to be with your restoration. Mine has J hooks, there are tabs attached to the gas tank that the hooks grab. They look like an easy add on if you want to go that route, but I've never seen a tank using fasteners so I can't say for sure. If you want to be accurate you need to change the radiator to take fasteners.
Josh
07-19-2003 01:58:45
 Re: Re: farmall (a) hood attachment. in reply to LanceM, 07-17-2003 15:28:14
I am restoring an A right now and I looked at a reproduction grill and they want $400+ for the grill so I would definatly not attempt to change that piece. I think the early tractors had the 1/4 turn and the later tractors had the J hooks...please lemme know if Im wrong.
