Farmall H steering parts
IH Man
07-18-2003 06:52:16
Where is the best source for Farmall "H" steering worm gear/shaft and sector gear?? Got a lot of play in mine and need to replace it.....
all feedback appreciated
Kelly C
07-18-2003 11:18:29
 Re: Farmall H steering parts in reply to IH Man, 07-18-2003 06:52:16
I have a extra sector gear.
Email me if interested.
Bob M
07-18-2003 11:17:35
A boneyard is the cheapest source for a replacement steering worm and gear. The risk of course is the replacement gear set will be no better than the one you've got now. Your CIH dealer can supply new parts, but they're gonna be costly - probably $200 - $250 range - maybe more.
If you are lucky the pivot shaft worm gear will be a full gear - with teeth all the way around. By removing the gear, turning it 180 deg and putting it back on the shaft, you'll bring fresh, unworn teeth into contact with the worm. However most of the H's I've looked messed with have had a half moon-shaped gear. This half moon gear has just enough teeth to rotate the pivot shaft between it's left and right stops. The gear cannot be turned to bring fresh teeth into contact with the worm.
Suggestion: Before you buy some expensive gears, check carefully both the upper end of the pivot shaft, also the worm shaft for looseness or play. Often replacing the bushing at the top of the pivot shaft and tightening or replacing the bearing/bushing that supports the worm shaft will bring the worm and gear back into proper engagement and will eliminate steering slop. I did this to my Super H a couple years ago - it completely solved a front wheel wobbling problem. And the parts (two bushings and a seal) cost less than $30.
Good luck!
Richard
07-18-2003 12:47:19
 Re: Re: Farmall H steering parts in reply to Bob M, 07-18-2003 11:17:35
Bob,
I looked at my M and the problem I have is worn bushings or bearings below the worm gear.
Any ideas on where to get a parts diagram or something to aid me in identifing the busings and how to replace them?
Thanks
Richard
Bob M
07-18-2003 18:06:16
 Re: Re: Re: Farmall H steering parts in reply to Richard, 07-18-2003 12:47:19
Richard – If you post your email I'll send you a copy of the parts catalog page with an exploded view of the bolster assembly – also the part numbers for the bushings/seal. Note the catalog I have is for the Super M. But far as I know believe a straight M is identical.
...Bob M
clif bice
07-27-2003 19:09:58
 Re: Re: Re: Re: Farmall H steering parts in reply to Bob M, 07-18-2003 18:06:16
Can You send me the pic of the hH steering? I also have a wobbly H . Thanks clif cbice@stlawrfcu.net
Richard
07-18-2003 18:43:03
Thanks for the offer of a view of the bolster assembly.
My email address is
haccount44@kc.rr.com
Richard
Bob M
07-18-2003 19:25:56
 Re: Re: Re: Re: Re: Farmall H steering parts in reply to Richard, 07-18-2003 18:43:03
Richard - Check your email! ...Bob M
dmartinsr@webtv.net
07-18-2003 14:03:15
Richard..... Jacobi Sales: Case /IH dealer in Seymour, Indiana has a lot of Farmall parts,seals, gaskets, bearings, and steering parts. Call them and ask for Roger in parts Dept.
Likes Red
07-18-2003 08:12:11
IH still has the parts however the worm shaft is probably $200. I'd try a salvage yard. If you find a gear you can turn the worn part to the side that isn't used and drop it back on the spleen. If your worm has wear in one spot you can turn the wheels to one side as you screw the worm back onto the gear. After everything is coupled up and you straighten the wheels to straight ahead the gear will be on a new unworn place on the worm. The worn place on the worm and the gear will not be noticible when you are turning the wheels.
justin
07-18-2003 16:04:33
 Re: Re: Farmall H steering parts in reply to Likes Red, 07-18-2003 08:12:11
The worm shaft is $306, and the worm gear is $170
