Order Farmall Cub Parts Online
Farmall Cub -1954
Ken
07-18-2003 08:38:53
I have a 1954 Cub that is hard or impossible to crank each spring but will not crank this year. It had been converted to 12 volt before I bought it. It has new plugs,wires and battery. It is getting gasoline but refuses to crank. Any ideas what the problem might be.
Bigdog
07-18-2003 09:24:15
 Re: Farmall Cub -1954 in reply to Ken, 07-18-2003 08:38:53
Start by replacing the points and condensor, rotor and cap. Once that is done, check the timing. Also, the plug wires should be solid core, not the carbon core type.
