Is my 51' H 6 or 12 volt?
Adam
07-18-2003 11:32:28
I just bought a 51' H and I was wondering how to tell if it is 6 or 12 volt. It has a 12 volt battery hooked up to it, but I don't know if it is correct. The H does not have any hydraulics, how hard would it be to find some for it and hook them up? At least a hydraulic remote, then maybe a 3-point later on. Maybe I could run a pump off of the un-used belt pulley?
Thanks.
Don LC
07-18-2003 20:55:26
 Re: Is my 51' H 6 or 12 volt? in reply to Adam, 07-18-2003 11:32:28
count the battery filler caps and x by 2 = .....
CNKS
07-18-2003 19:38:34
You sure it doesn't have hydraulics? Most came with a belly pump. The rod and lever could be missing. Remove the plate from the bottom of the torque tube (clutch housing) and look inside. If you see nothing but a clutch shaft, then you are right. You can add live hydraulics by using the pump (mounts in front of the distributer) from a Stage 2 Super H along with the cam gear.
Doug in OR
07-18-2003 16:33:01
It came factory-equipped as 6 volts. If someone converted it, I couldn't say.
