will a 460 WFE fit 560 and later?
Michael
07-18-2003 14:24:02
Will a 460 WFE fit the 560 and larger 06 series tractors?
Were all of the WFEs the same?
RPM
07-19-2003 08:58:57
 Re: will a 460 WFE fit 560 and later? in reply to Michael, 07-18-2003 14:24:02
All later WFA from IH to fit SM/SMTA/400/450/460/560/656/706/56/806/26/56/1206/56 will fit up to frame and steering, differences are spindle type and bearing size. Also there were Hi-Clear types but very uncommon in midwest. To identify older SM-450 they had nc (coarse) 7/8 threads, 460-656 had fine 3/4 threads, 560-706 and up had 7/8 fine threads to adjust bearings in wheel hubs. There are other variations such as 1026/1456 and 66/86 types.
K.B.
07-18-2003 16:02:08
Should fit 560. Not sure but it might take minor work to make it fit 06, 26, 56 series. No, all wide fronts were not the same. 460 and 560 had the same wide front. 06, 26, 56 series, 666, 686, and the 544 Row Crop had the same front end mounting as each other, with a couple different sizes of front ends, that all interchange. 66, 86, and 88 series had the same wide front as each other, with late 86 series and 88 series having a one-piece bolster.
