806 fuel bowl of carb
Lee
07-18-2003 16:02:36
I am building an anitque tracter puller. I wont to use a fuel bowl of a 806. Can you tell me what to look for to make sure I am geting one of an 806.
ChadS
07-19-2003 09:03:24
 Re: 806 fuel bowl of carb in reply to Lee, 07-18-2003 16:02:36
A 806 carb bowl does not have a brass plug on the bottom of the bowl. This brass plug holds the metering stem in place on the older carbs, the 806 metering stem is threadded into the bowl. So look for the brass plug on the bottom of the bowl, if it has it, it is not a 806. You can find them on 303-503 IH combines as well. I have 5 806 bowls if you are interested. 574-893-7437 ChadS.
