Clutch pilot bearing
John
07-18-2003 16:52:45
I am finally getting back to working on my IH 154 Cub Lo-Boy clutch. When I assemble it, I was wondering if I should put some grease on the small round part that goes into the clutch pilot bearing? Thanks.
LanceM
07-19-2003 10:02:50
 Re: Clutch pilot bearing in reply to John, 07-18-2003 16:52:45
I agree with Dave that it may depend upon what your bearing is made of but I would say yes a little dab in the bearing and a little dab on the shaft. Like Dave said too much could be thrown off and ruin the clutch, but no lube on the pilot bearing and it will catch the shaft over time and make it difficult to shift gears as the shaft won't stop turning, making it seem like the clutch is engaged.
Dave_Id
07-18-2003 18:54:41
A light coat certainly won't hurt, but the bearing is made of "oil lite", some are even impregnated with graphite. Too much grease will fly off and could contaminate the clutch disc.
