International A smoking
Larry Hardesty
07-19-2003 06:51:39
I got a 1946 International A and it smokes a little gray smoke and uses some oil--maybe half a quart every 4-6 hours. I just use it every couple of weeks in the summer to mow 2-3 acreas so the oil consumption is not a big inconvenience. I assume new rings are in order (how can I check?). Is this a job for shop or can a newbie do it? Thanks
LanceM
07-19-2003 09:49:02
 Re: International A smoking in reply to Larry Hardesty, 07-19-2003 06:51:39
Considering your useage I wouldn't worry about it. It will probably run that way for the next 20 years if all you do is mow a couple of acres every couple of weeks.
Best way to check the rings is by doing a compression check.
Newbie?? New to tractor mechanics or new to mechanics? That can be a hard question to answer but these are probably the simplest engines ever made to work on, if you have tools, a clean place to work, the desire to learn and a good set of shop manuals for your A I think most anyone could rebuild the engine. There is always a lot of help on this board too if you run into something that's not explained in the manuals.
Larry Hardesty
07-19-2003 20:40:15
 Re: Re: International A smoking in reply to LanceM, 07-19-2003 09:49:02
Done about everything but tear into the engine of a tractor (paint, replace seals, etc.). Do have shop and some tools. Thought it might be a good learning experience--but do not want to learn too much the hard way!! Thanks
