side pulley
randy Jones
07-19-2003 15:26:54
I have an H and would like to know if a shaft can be mounted on it to run a hydrilic pump. thank you for any help
BIG JOHN
07-19-2003 19:11:33
 Re: side pulley in reply to randy Jones, 07-19-2003 15:26:54
A Char-Lynn Power Pak will run off of either the PTO or the Belt Pully. If you haven't seen one it is a complete Hydraulic system all in one. They are great for adding hydraulics to either an "A" or "B", but can be used on any tractor.
Dave_Id
07-19-2003 18:12:25
There is a Farmall M in the neighborhood that has a belley pump, a hydraulic pump running of the pto shaft, and yet another running off the side belt pulley... he comes prepared
Jon
07-19-2003 15:38:38
I'm sure you could somehow, but it wouldn't be live. Looks like fixing the lift-all belly pump would be easier.
