A Tie Rod replacement
Scott in SC
07-20-2003 04:57:59
Need to fix my Brother in Law's red tractor. I'd guess late 40s-early 50s A. "Tie Rod" end snapped at the left front wheel on the end of the rod that runs from the steering box. (It's really more like an old drag link). Does anyone make new replacements, or am I off to the bone yard? As you may have guessed, no IH/Case store close by. Thanks for the help!
gene b
07-20-2003 12:17:37
 Re: A Tie Rod replacement in reply to Scott in SC, 07-20-2003 04:57:59
Send you tie rod to WILLIE KANA he will make them like new 979-247-4003
Hugh MacKay
07-20-2003 09:17:25
Scott: I can't tell you on availability of parts. Just advising that near 1950-51 that whole ty-rod assembly changed. The old ones looked as you say a drag link. The new type are automotive type ty-rod end with tapered pin with ball and socket. Which is better I cant tell you as I have only ever had the new type.
Reddog
07-20-2003 09:03:37
I got a tie rod end from Bates Corp. Hope that helps.
