F-12/14 front wheel hub replacement casting code??
Zak
07-20-2003 17:47:07
Howdy folks! Here's my question of the week. I have an F-12 (yeah I have a parts book too) and it has boogered (no offense Boog!) front wheels. I also have a local tractor junkyard that has stacks of front wheel hubs. Say I wanted to use the front hubs with the clamp-on type rims from an H or whatever. Is there a known casting code that I can look up on the hubs at the yard so that I know they'll fit my F-12? I've seen some F12/14's with this type of rim so surely sombeody knows. Thanks all! Zak P.S.- I'm getting closer and closer to painting day! next stop, engineville!
Guy Fay
07-20-2003 19:14:03
 Re: F-12/14 front wheel hub replacement casting co in reply to Zak, 07-20-2003 17:47:07
Minor terminology quibble- casting code usually refers to the casting date code, what you're asking about is referred to as a parts number- two different things.
Zak
07-21-2003 05:48:48
 Re: Re: F-12/14 front wheel hub replacement castin in reply to Guy Fay, 07-20-2003 19:14:03
My mistake! Ok...I'm looking for the cast part number then from a known wheel hub that'll fir the front axle of an F12/14. Thanks Guy, Zak
