Overheating 350 Utility-followup
Jim E
07-20-2003 20:32:41
Still don't know exactly what was causing it but cleaned built up dirt from radiator, replaced worn out blades on bush hog, replaced condensor and coil (it would quit running after 5-10 minutes-gas flow was OK). Ran it 4 hours and the only time it got warm was when the grille was plugged from weeds.
THANKS!!
Jimmy King
07-21-2003 03:33:23
 Re: Overheating 350 Utility-followup in reply to Jim E, 07-20-2003 20:32:41
either your heat gage is no good or thermostat is no good I would go with the latter first. more likly to be, cheeper, and easer to change.
