Super A Govenor
scotty
07-21-2003 06:39:21
My first question, is there supposed to be a gasket between the govenor and engine block? Took it apart this weekend and just permatex sealant. Second question, the speed control lever seems a little sloppy, have any of you guys put a bushing in there for a better fit. I also noticed there was no felt seal there on the outside of that lever which I assume was to cut down the oil leakage from that housing. When the engine is running I would guess that housing fills with oil.
Thanks
scotty
J MIRGON
07-21-2003 16:30:27
 Re: Super A Govenor in reply to scotty, 07-21-2003 06:39:21
I Do know for sure that there is a gasket between the block and the governer, Sorry I am unsure on the other questions.
