Brakes????
Dann
07-21-2003 08:21:05
Ipurchased a set of Value built brake bands for my M farmall part no# 11127-095 They don/t seem to want to close up enough when you put the dog and pins in they run out aginst the brake cover housing. The old ones have open area between cover and band but fit loose around brake drum but the dog lays in more of a twist,or wrap like a closed "C" the new ones wont close any Ideas? Thanks!!!!
Scott -M
07-23-2003 17:55:20
 Re: Brakes???? in reply to Dann , 07-21-2003 08:21:05
I just put bands on my 39 M the new ones did not rotate well on the pins, I took a grinder and narrowed up the ends of the bands to fit into the old pivot pins then reshaped the bands to go aroung the brake drum.
Jcnc
07-21-2003 08:45:07
I bought a set from the Case/IH dealer for my H, and they also were almost too big to fit inside the cover. I had to adjust the bottom screw outward as far as it would go, and I had to shape the brake band into a better shape in order to get the cover on. Even so, it is a tight fit and the brakes drag just a little.
