Farmall H Price
Matt Oney
07-22-2003 12:16:46
Hello. I have a 1949 Farmall H that I'm trying to sell, and I'm trying to get an idea of the price for it. First of all, both front tires are flat, however I am changing those before it gets sold. The wiring from the battery to the starter button to the starter and all that is shot, and that will be replaced as well before sold, if I know whether the tractor will be restored. As for everything else, it works good, just needs a new coat of paint. Haven't ever seen this tractor leak, and we just changed the oil. The biggest problem is I can't get it to start. I've put on new points plugs and condensor, I know I'm getting good fire. I know it also has VERY good compression. Its got everything it needs to start, it just won't. So any ideas about that would be very much appreciated! Please if you can, email me because I will forget to look at this site. Thanks for your time.
Rob
07-22-2003 18:06:44
 Re: Farmall H Price in reply to Matt Oney, 07-22-2003 12:16:46
If you have good fire and have not messed with timing my suggestion is start on the fuel system by first removing the sediment bowl turn fuel valve back on and see that gas flows freely from the tank.If it does then go to the other end of the line at the carb screw the line loose from the carb there is a screen on the end that fits into the carb and it may be plugged If all that is clear and it still wont start then you may want to remove the carb take cleaner to it dissassemble it soak in carb cleaner for awhile and put it back
JOHN CASE
07-22-2003 20:19:38
 Re: Re: Farmall H Price in reply to Rob, 07-22-2003 18:06:44
DID YOU CHECK THE POINT CLEARENCE I HAD THE SAME PROBLEM ON MY C.
TomH
07-22-2003 17:11:48
Double check the ignition timing. Spark on compression stroke, not just on timing mark. If just a sniff of starter fluid doesn't give you a pop it's probably way out of time.
Farm w/Junk
07-22-2003 16:53:31
Where are you located? I maybe interested in the tractor. Just email me.
Matt
Dave_Id
07-22-2003 12:39:53
Look in the Photo Ads, and the other classifieds on this site, and see how much other people are asking for theirs, and while you are at it, post an ad for your tractor, only YOU knows how much you want to get for it
Matt
07-22-2003 14:32:05
 Re: Re: Farmall H Price in reply to Dave_Id, 07-22-2003 12:39:53
Thanks. I'll check em out. The problem around here is everyone expects me to just say "here you can have it." If I attach a price tag to it, nobody wants it. I've been asking $750, I don't think thats too unreasonable do you?
Dave_Id
07-22-2003 15:48:21
 Re: Re: Re: Farmall H Price in reply to Matt, 07-22-2003 14:32:05
That sounds real reasonable for a running H.
