What's the difference
Angie
07-22-2003 14:01:09
What's the difference, if any, between the model A and a Super A?
CNKS
07-22-2003 19:17:42
 Re: What's the difference in reply to Angie, 07-22-2003 14:01:09
Hydraulics, the engines are and other parts are the same. Super A-1 had a bigger engine, water pump and larger radiator.
CNKS
07-22-2003 19:01:43
TimV
07-22-2003 14:38:07
Angie: The most obvious difference is that the Super A has hydraulics. Specifically, if you look just behind the engine, you will see a shaft sticking through from one side of the tractor to the other, usually with a couple of arms on it that go back toward the driver's seat. There will also be another hand control lever by the throttle that controls these. There are several other differences (more powerful engine, for instance) that are more difficult to tell.
angie
07-22-2003 20:38:26
 Re: Re: What's the difference in reply to TimV, 07-22-2003 14:38:07
Thanks you guys, this was the exact information I needed.
TimV
07-23-2003 05:51:29
 Re: Re: Re: What's the difference in reply to angie, 07-22-2003 20:38:26
Angie: Glad we could help! Now a question for you--what indication do you have that this is a 1945 Farmall A? By the serial number you gave in your first post (serial plate should be on the left seat bracket, by the way) it's a 1941 A. The Super A's didn't start production until 1947, and I believe the starting serial # was SA250001.
