SMTA Brake Question
Tom
07-23-2003 17:53:16
The left brake on our SMTA fully engages (locks) intermittently when applying gentle pressure on the brake pedal - instead of engaging gradually. The disks are new, the mating services for the disks have been resurfaced, new balls and springs installed and no oil leaks. The right brake works perfectly. Suggestions please. Tom
here, try this
07-23-2003 18:08:33
 Re: SMTA Brake Question in reply to Tom, 07-23-2003 17:53:16
ooohh, how much material did you take off. You might have to take material off the cover so the caliper don't open as far. With the cover off the tractor lay both shoes and the caliper in and with a straight edge see how much room is left to the lip of the cover. It shoud not be very much probly 1/8 - 1/4 at the most.
chub
07-24-2003 04:27:47
 Re: Re: SMTA Brake Question in reply to here, try this, 07-23-2003 18:08:33
Have had this problem when I installed new brke discs and have learned to take a die-grinder and clean up all the splines on the new discs as well as the tractors brake shaft they ride on. It does the job for me!
