F-30 woes
here, try this
07-23-2003 18:04:05
Seems like old times. finaly got back to this F-30 that has been haunting me for a year now. I had to change one of the final drives as the bearings were bad. Now I am trying to get one more pair of brake shoes fron the donor. anybody have any idea how to unstick the drum. The set on the other side i made a puller and insted of brake shoes I break shoes. I don't realy want a repeat as this is my last chance.
Bobcat
07-24-2003 07:06:58
 Re: F-30 woes in reply to here, try this, 07-23-2003 18:04:05
Here try this, You will have to use the puller. But,don't get in a hurry with it. Use lots of tapping with a hammer on the drum. Try rocking the drum back and forth. The brake shoes are made of cast iron and tend to stick to the pivot shaft. If you have plenty of time you could remove the oil/grease zerk from the housing and try getting penetrating oil to flow to the pivot point. If the shoes break they can be welded back together. New linings can be custom made for less than $50. Leave E-Mail link if you want a address.
here, try this
07-24-2003 17:46:09
 Re: Re: F-30 woes in reply to Bobcat, 07-24-2003 07:06:58
i guess i could weld the broken shoes but i hate to weld. I am thinking about using the torch on the drum as i have extras anyway.
You might consider this..
07-23-2003 18:18:40
Huh? You what?
yes i did
07-23-2003 18:27:07
 Re: Re: F-30 woes in reply to You might consider this.., 07-23-2003 18:18:40
did you ever do that?
