fender lights
Bryce Andreasen
07-23-2003 21:19:45
Bought some used fenders for the 1466, wich had the short IH cab, not the long white or red style or the year-a-round, but the air went out years ago, and heat doesn't work, only fan and radio. took the lights off to paint the fenders, but never did know whitch lights come on when. It has the more fine lined light on the inside, and the more coarse linesed light on the outside. Whitch light would come on with the light switch on the first and second notch, that would also turn on the flashers? But than both lights would come on with it on the third notch? Also, it had many drilled holes in it, and only one hole towards the back on the left fender for the flasher, was there originaly suposed to be one light or two, the right fender doesn't have a hole in the back outside.
Jerry
07-25-2003 05:35:40
 Re: fender lights in reply to Bryce Andreasen (Magnum), 07-23-2003 21:19:45
Not real sure about IH, but on my MF1155 the light switch has a dim, then a bright with a work light for the back, then a bright with flashers.
If the tractor doesn't have flashers on both sides then the common thing was a flasher on the left fender as to be to the inside of the lane of traffic.
