Farmall 560 Glow Plugs
JB Bratton
07-24-2003 09:18:25
I'm pretty sure I need glow plugs in my 560. Are they diffucult to replace? Are there any tricks that I need to know? Thnx =JB=
Hugh MacKay
07-25-2003 17:41:08
 Re: Farmall 560 Glow Plugs in reply to JB Bratton, 07-24-2003 09:18:25
JB: You can tell right from your tractor seat if glow plugs are working and if they are not your gauge will tell you how many are not working. That gauge is showing amps drawn and each plug requires so many amps. I have forgotten the exact amps drawn, been 18 years. If the hand on gauge is going almost to the right they are all workng. You can pretty well dervide it out on gauge. A simple test light between supply wire and glow plug will tell you which ones are bad.
The major problem with 560 glow plugs is care or lack of it. Your battery cables must be 1 gauge all soldered on ends. Your cables must be kept clean. And last you must use those glow pluges a min of 1 min. even in hot weather and suposeing the tractor was going 20 minutes ago. In sub zero weather I have held 560 glow plugs on for 5 minutes. There is just one place for that ether can, that being an emergency at -20F For cold weather starting use a circulating block heater. I used to start my 560 daily at temps as low as -35F , the secret block heater, just like a summer time start. Remember roughtly 85% of engine wear occurs while engine is not up to temperature. To me, a block heater is about starting, but more important than starting is engine wear. Get that engine up to temperature quickly as possible.
Most diesels will not maintain ideal operating temperature if left idleing in minus 20F weather.
I have a little story about a guy with a 656 diesel same engine as your 560. He used to haul heavy loads down a 3 mile incline, and would pullback on his hydraulic valves using them basically like engine brakes, and even then the tractor would over rev. One day the tractor stopped and wouldn't start. I was told that push down the hill in cool weather cooled engine to point it stopped firing. They had to use glow plugs to restart. I understand this wasn't the first time. The first time tractor sat for two days, owner wondering what was wrong. He thought he had broken something. After two days of consulting people in the know, They went back to tractor, using glow plugs of course, and tractor fired right up.
Jim
07-25-2003 07:35:30
There are two types of glow plugs in a 560; Good or burned out. I check them with a test light.
Jimmy King
07-25-2003 05:20:56
Take each glow plug out and plug it in make sure it is grounded push your glow plug button it will just take 3or4 seconds if they are good to get red hot about 1/2 inch on end.
ronohio
07-24-2003 19:38:23
JB, what makes you think you need glow plugs. I'd like to know because I have a 560 and the glo plugs seem to do nothing. Maybe I don't wait long enough. If I want to start it I use ether. It would likely never start even in the summer with glo plugs or even whenm hot. The shop rewired it and put new gages on it. There is a glo plug gage but I don't know what it shows except it goes up when you put the glo plug switch on. Any info would be appreciated. Thanks, Ron
K.B.
07-25-2003 15:57:49
 Re: Re: Farmall 560 Glow Plugs in reply to ronohio, 07-24-2003 19:38:23
How long do you leave the glow plugs on? Even on a 90 degree day, the proper procedure is to hold the glow plugs on for at least one minute, start the engine, and keep the glow plugs on until the smoke clears up.
Val
07-24-2003 10:25:36
I've been around these glow plug tractors since 1963. From experience I will recommend that you use an anti-sieze compound on the threads and do not over tighten the glow plug or it will be real tough to get out next time. I use a 6 point deep well socket which seems to work real well.
