Farmall Super C for Parts or maybe...just maybe!!!
Scott L. Swanso
07-24-2003 10:12:03
I purchased a Super C from a fellow last weekend. He wanted the Grill and Radiator so I got everything else. Most of it is in good shape. However...I pulled the head, fully knowing it had been froze up for a long time. The head does not look too bad. The pistons are all froze up real good..I mean bad. I dropped the oil pan and looked up in there. The crank and everything below looks new, well 1952 new.
Are these engines rebuildable like the H's. I know it has wet sleeves while the H's have dry sleeves. Should I mess around with the motor or offer the extra parts to all of you out there at a great price?
I would have to assume Super C engines are a little harder to find than regular A-B-C engines. Should I make the effort and see what happens?
I yanked out the push rods....ewwwww ww! Pretty nasty looking. I suppose the camshaft looks like warmed up refried beans.
Any suggestions?
Thanks,
Scott
derby58
07-25-2003 10:19:41
 Re: Farmall Super C for Parts or maybe...just mayb in reply to Scott L. Swanson, 07-24-2003 10:12:03
How long has it been set up? I took an A that was tighter than a drum and soaked it for 3 months and then hammered(hard) the pistons down until it was free. I had to clamp the sleeves down so they would not push. After I got it free I put it back together and she ran. She smoked like crazy the first year and I had to change the oil often but I put it to work and now it runs like a top. If you have the time it was a lot of fun.
CNKS
07-24-2003 18:38:34
Won't be profitable, but you can find C123 parts anywhere. Value bilt has a piston and sleeve set for $310, a rebuilt block for $1300. Tractor will run like new, but cost more than new. Most of the letter series engines have a lot of sludge in them, doesn't necessarily mean the cam is bad.
BIG JOHN
07-24-2003 15:27:56
It will cost you $300.00 + just to replace the parts that he kept. This plus what you have said would FOR SURE make it a parts tractor for me. You can probably part out (sell the rest of the parts) for enough to buy a good "C" in running condition. It is the old story - "THE SUM OF THE PARTS IS GREATER THAN THE SUM OF THE WHOLE".
Gary_N_WV
07-24-2003 12:53:02
Where are you located Scott?
Scott Swanson
07-24-2003 19:44:58
 Re: Re: Farmall Super C for Parts or maybe...just in reply to Gary_N_WV, 07-24-2003 12:53:02
The tractor is located in Park Rapids, MN...One hour South of Bemidji.
I am going to have the head and block checked....if bad is the word---selling Super C parts is my new profession for the short term.
Scott
Gary_N_WV
07-24-2003 12:46:59
Hmmmmm mmmm....Do you like working on things?
Can you do the work yourself?
If you have time, money and desire..... .go for it !
I think you can get about anything you need for the engine...check the link at the top left of this page....and there are lots of salvage yards.
G'day
