Re: Re: Re: Re: Re: correct tires
Hugh MacKay
07-25-2003 03:20:40
Michael: If you notice the size on that tire it will likely say 9.5 x 24 on 8" rim. If you look at new 11.2 x 24 tire size it will say on a 10' rim.
Yes you have one wheel made of heavy cast, and is designed to be used on right to balance the offset tractor.
Michael
07-25-2003 15:48:03
 Re: Re: Re: Re: Re: Re: correct tires in reply to Hugh MacKay, 07-25-2003 03:20:40
Thanks for the help there for a while I was thinking I had mismatched part
