W4 starter removal???
Jim in Michigan
07-25-2003 10:38:44
We bought a W4 from the original owner,,its a 1948. It has a starter on it but has never been used. The guy said they bought it and it was delivered in the winter, battery froze and broke and they couldnt afford to buy a battery after spending all the money on the tractor and such (maybe he is pullin my leg here) But anyway, I need to repair the starter , I took the battery box off and the 2 bolts out of the starter, but I see no way of getting it out, the rear of the starter hits the transmission housing before the starter nose is out of the hole,,,any ideas???? Anyone wanna buy a W4 that needs starter work? ,,,,Jim
here, try this
07-25-2003 19:04:59
 Re: W4 starter removal??? in reply to Jim in Michigan, 07-25-2003 10:38:44
I took a bolt out of the trans case and with that and holding my mouth just right I was able to get the starter off.
Jim in Michigan
07-26-2003 05:48:25
 Re: Re: W4 starter removal??? in reply to here, try this, 07-25-2003 19:04:59
looks like someone has ground on the bolt a lil bit, doubt I culd get it out,,,Jim
here, try this
07-26-2003 18:03:22
 Re: Re: Re: W4 starter removal??? in reply to Jim in Michigan, 07-26-2003 05:48:25
yup, that's the bolt. wonder if the other guy got the starter off?
Jim in Michigan
07-27-2003 07:03:44
 Re: Re: Re: Re: W4 starter removal??? in reply to here, try this, 07-26-2003 18:03:22
nope,,no one has got it off yet,, tractor is my dads and he is thinking about doing some grinding on it too,,I am trying to keep him from it, but he is stubborn lol...When I get a free time I will take the belt drive off and fix the starter right, hopefully I can get to it soon,,county fair is the 30th and I would like to take it to the swap meet...Jim
Bill V
07-25-2003 16:37:16
I have a W4 that is having starter trouble also and have just been cranking it to start because of the trouble getting the starter off. If the tractor has a belt pulley unit on it, it will have to be removed and probably the gas tank to get the pulley unit off. With all that out of the way it will come off, it is a very tight fit and will have to be posistioned just right to get in and out. Good luck.
Jim in Michigan
07-25-2003 16:40:26
 Re: Re: W4 starter removal??? in reply to Bill V, 07-25-2003 16:37:16
Sounds like a lot of work,, I bought the tractor to resell it,,,I have posted it on the YT classifieds, I dont have time to mess with it right now so I think I will shove it in the corner and hopefully sell it to someone who has more time,,Thanks,Jim
