M Water Pump Question???
Big Red
07-25-2003 18:51:12
Hey guys, I have been noticing a small amount of water leaking out of one of the grease fittings on the water pump on the left side of the engine, and some water comming out from the front of the fan. This doesn't seem like a bad leak because I check the fluid level every time before I crank the tractor and it's always pretty close to full. I've even let it sit for 3 or 4 days and then checked it and it's still pretty much full. can any of you tell me what's wrong?? Do I need a new water pump?? If I do can I get one anywhere else besides CaseIH or Napa?? All opinions would be appreciated and thanks again!
here, try this
07-25-2003 18:57:37
 Re: M Water Pump Question??? in reply to Big Red, 07-25-2003 18:51:12
you can still get the shaft packing from IH
Big Red
07-25-2003 19:32:49
 Re: Re: M Water Pump Question??? in reply to here, try this, 07-25-2003 18:57:37
Can any of you tell me where the packing nut is located?? If shaft packing is required, how do I go about doing this? Thanks again!!
CNKS
07-25-2003 19:43:09
 Re: Re: Re: M Water Pump Question??? in reply to Big Red, 07-25-2003 19:32:49
I have never repaired one while on the tractor, I remove the whole fan assembly, disassemble the water pump and replace anything I think it needs. But the nut is on the end of the water pump shaft. You may (not sure) have to remove something called the "water pump driver" that has two studs on either side with two springs. Someone bail me out. CRS is setting in.
49 Cubber!
07-26-2003 03:39:26
 Re: Re: Re: Re: M Water Pump Question??? in reply to CNKS, 07-25-2003 19:43:09
Yep,the driver has to come off first.Remove the locking bolt,pull off the drive and the two springs.The NUT doesnt look like a regualar nut.Just tighten it up and try that first,but its been my experienc that unless its just recently been rebuilt,you need new packing.
CNKS
07-25-2003 19:16:43
Part Number is 50790D. Get 3 or 4 of them, as you may need more than one. About $2.50 each. Try tightnning the packing nut first, that may stop your leak.
