966,1066 ??????
Jeremy
07-26-2003 19:14:07
I was wondering what is the difference in a black stripe and a white stripe on 966,1066??? what would be better a 966 black stripe or 1066 white stripe???? Thanks Jeremy
TP from Centra PA
07-27-2003 06:43:49
 Re: 966,1066 ?????? in reply to Jeremy , 07-26-2003 19:14:07
I thought they turned the pump up on the Black Strips a tad..... ..... I read they re-tested them at Neb. so they had to change something(Engine Wise).
randy hall
07-27-2003 19:20:19
 Re: Re: 966,1066 ?????? in reply to TP from Centra PA, 07-27-2003 06:43:49
in '73 ih raised the rpm's and retested at nebraska to catch up with the new deere's to even up the horsepower.
Chuck
07-26-2003 19:26:24
Late 66 series tractors have black stripes. There is no difference in the tractor underneath.So I guess its all in what you like...
Hugh MacKay
07-26-2003 20:52:50
 Re: Re: 966,1066 ?????? in reply to Chuck, 07-26-2003 19:26:24
Chuck: Close but not completely so the black stripe tractors are slightly different. Not completely sure on the change due to memory, but I believe the black stripe tractors have larger axles. It's only 1/8 inch. The upgrade was same as what was coming on 86 series tractors. When I say this I am speaking of 1066 and 1086, as I bought a new 1066, probably one of the last before black stripe.
JimB
07-26-2003 22:22:53
 Re: Re: Re: 966,1066 ?????? in reply to Hugh MacKay, 07-26-2003 20:52:50
No the axles are the same.
Hugh MacKay
07-27-2003 08:13:21
 Re: Re: Re: Re: 966,1066 ?????? in reply to JimB, 07-26-2003 22:22:53
Jim: In 1976 or 77 the dealer told me what the difference on black stripe from regular 66 series tractors. I quite frankly cant remember what he told me. There was a discussion here on forums last fall regarding the difference. It is in the archives. It is in rear of tractor. What we need is one of the old IH parts guys with numbers.
wgatewood
07-27-2003 15:05:15
 Re: Re: Re: Re: Re: 966,1066 ?????? in reply to Hugh MacKay, 07-27-2003 08:13:21
hiug the difference in the white and black stripe is the three point hitch arms , and the rear axle housings these were already set up for the 86 series
Hugh MacKay
07-27-2003 16:26:33
 Re: Re: Re: Re: Re: Re: 966,1066 ?????? in reply to wgatewood, 07-27-2003 15:05:15
Thank you, I knew there was something different back there.
