sickle bar mower for 230 IH
.w. S. Ribelin
07-27-2003 13:29:11
I have a sickle bar mower for my 230IH fast hitch.I do not have all of the attaching parts or a manual. If someone knows of a manual that gives parts and mounting instructions,I would like to aquire one. Thank You, WSR
Jimmy King
07-27-2003 14:05:34
 Re: sickle bar mower for 230 IH in reply to .w. S. Ribelin, 07-27-2003 13:29:11
If I remember right all you should have is a chain with around peg about 4 inches long on one end the other end on a lever on the lift bellcrank there should be a hole at the back of the platform just under it, the peg goes in it and a bolt thru. it. When you raise the 2 point the chain tightens and raises the sickle bar and let it down to lower. and of course your 2 point points should be on the mower. This was simpler than the Super C and 200 which had a bar to lock the mower in one place and a lift arm then went to the touch control arms.
