H serial number?????
Jeremy Napper
07-27-2003 17:13:26
I have a H farmall that is missing the serial number tag. It has a belt pulley and a distributor. I have a 1943 H that does not have a belt pulley. Any help is welcome. Thanks-Jeremy
rustyfarmall
07-27-2003 22:04:32
 Re: H serial number????? in reply to Jeremy Napper, 07-27-2003 17:13:26
The belt pully was on option, most had it, some didn't. Also optional was the PTO, the hydraulic pump, and the electrical system. Standard was a magneto and a hand crank.
Larry
07-27-2003 17:16:28
You should find the serial number stamped on a boss on the block right under the front spark plug. If the engine has never been changed this would be your serial number.
Jeremy Napper
07-27-2003 17:21:12
 Re: Re: H serial number????? in reply to Larry, 07-27-2003 17:16:28
Thanks Larry, But what I should have said is the serial tag is not on the tractor. It was missing when I got it.-Jeremy
Mike ISW
07-27-2003 17:50:39
 Re: Re: Re: H serial number????? in reply to Jeremy Napper, 07-27-2003 17:21:12
What Larry means is the same # is stamped on engine block that was on serial # tag. Assuming block is original this would match your serial # tag. HTH, Mike
