300 hyd pump buzzing
26Red
07-28-2003 09:44:15
I recently rebuilt the hyd. pump on my 300 and added a adjustable priority valve to run the powersteering. The pump and lines are making a moderate "buzzing" sound- is this normal? or should I try a larger priority valve (larger ports)? It is spliced into the pressure line coming from the pump. The port size is currently 1/2". The valve is rated for 0-16 GPM.
Bob
07-29-2003 04:49:31
 Re: 300 hyd pump buzzing in reply to 26Red, 07-28-2003 09:44:15
Priority valves commonly "buzz".
Aces
07-28-2003 10:15:13
If ti is rated for 16 GPM the port should be big enough becasue you pump is only 12GPM. the buz could be a high pressure some place.
