leaking around radiator
rterry
07-29-2003 04:03:54
I replaced the radiator gasket. Still water is coming from some where. dripping on floor. Should I replace the bolts need help.
red4now
07-29-2003 19:18:54
 Re: leaking around radiator in reply to rterry, 07-29-2003 04:03:54
if you are talking about a Cub, make sure both surfaces are very clean and maybe a very small amount of permatex to help seal. do not suspect the bolts are the problem. good luck.
cornchip
07-29-2003 19:14:31
might check the muffler bearings as well.
CNKS
07-29-2003 19:04:53
Probably should not respond -- sounds like a "joke"
Gary_N_WV
07-29-2003 08:53:28
I would think that you need to figure out for sure where the coolant is leaking from before you can make a decision on how to fix it.
What gasket did you replace?
rustyfarmall
07-29-2003 05:38:37
On what?
Dana
07-29-2003 07:00:09
 Re: Re: leaking around radiator in reply to rustyfarmall, 07-29-2003 05:38:37
Sounds like a leak in your radiator to me. Maybe a bad hose.
