My battery gets drained after running my Farmall S
Cliff Davis
07-30-2003 23:16:49
After running my Super A off and on for a few days I have to recharge the new battery. The tractor will sputter and then the engine will stop.
Hugh MacKay
07-31-2003 02:58:35
 Re: My battery gets drained after running my Farma in reply to Cliff Davis, 07-30-2003 23:16:49
Cliff: More details, What is amp gauge saying? Is tractor 6 or 12 volt? Generator or alternator?
Cliff Davis
08-05-2003 05:10:59
 Re: Re: My battery gets drained after running my F in reply to Hugh MacKay, 07-31-2003 02:58:35
Sorry it to so long to get back to you, Hugh.
It's a 6 volt with generator and the amp guage reads, -5.
Thanks,
Cliff Davis
Hugh MacKay
08-05-2003 05:29:14
 Re: Re: Re: My battery gets drained after running in reply to Cliff Davis, 08-05-2003 05:10:59
Cliff: Definately not charging, could be regulator or generator. Do you have a manual with wiring diagram to check that everything is right with wiring. Will tractor keep running if you remove a battery cable? Are your battery terminals clean and in good condition? I'm running shy on time just now but go to left of page under Research and Info, check in articles or tune up specs for some ideas I am thinking look at polarity of regulator. I'm just forgeting on that one.
Cliff Davis
08-05-2003 05:19:13
