IH No. 100 Balanced Mower
crockofbc
07-31-2003 10:48:24
I have an IH No. 100 Balanced Mower w/ 2 point fast-hitch that I use on a Super C. I need to change some of the lifting parts so I can attach it to my 460.
Could anyone out there give me a few measurements? The straps that attach to the fast-hitch cylinder bellcrank, stud and sleeve that attaches to the bearing plate on the right side of the fast-hitch rockshaft and the length of the 2 chains (lift and support) would be good to know also.
Tractor Dan
07-31-2003 14:55:14
 Re: IH No. 100 Balanced Mower in reply to crockofbc, 07-31-2003 10:48:24
i run my ih 100 with my 350 diesel i welded a bracket to the left hand fasthitch shank and used a small hydraulic cylinder hooked to the same place you hook the rod that would go to your rock shaft on the super C it works very well except it is hard to get the guards tipped back with out lowering the mower near the ground
