Rear wheels for a B
Mark
07-31-2003 19:02:48
Does anyone know what other rear centers would fit on a Farmall B? I know for example that AC WC wheels will bolt up to an F20. Thanks in advance, Mark
BIG JOHN
08-02-2003 12:42:12
 Re: Rear wheels for a B in reply to Mark, 07-31-2003 19:02:48
Pick up some Wheels/Rims/Tires at at farm sale that were said to be FARMALL. Didn;'t question because they were the right red color and there weren't anything but FARMALLS on the farm.
It turned out that they were off of one of the small AC tractors. I don't know my AC's so I can't tell you what model. The centers (Wheels) were the same. (I have also been told by a salvage dealer that both brands used the same wheel.) While the rims were both 24" alright, the way that they attached to the wheel was different. The Farmall uses a bolt and clip that is welded to the rim, the AC uses a wedge and a cam bolt to attach the wheel to the rim.
Each of them would work on either tractor, but they will not mix and match unless you keep the wedge and cam bolts with the AC rims.
GOOD LUCK
Heat Houser
08-01-2003 08:48:32
Don't know about the centers, but I think the rims are the same as a Ford.
CNKS
08-01-2003 19:14:52
 Re: Re: Rear wheels for a B in reply to Heat Houser, 08-01-2003 08:48:32
Ford is 28 inch, A, B, BN are 24 inch.
