460U front loader lift capacity
Doug Stockman
08-02-2003 04:20:24
Greetings:
I have a 460U with a front loader on it. The tractor has over 6,200 hrs on it so most everything on the tractor is worn. At present my front loader which is powered by the standard hydraulic pump (12 gpm at 1,500 psi) has trouble lifting 700 lbs. At some point I will get a pressure gauge and probably verify I need the pump rebuilt. I think I saw somewhere that this tractor could lift 1,500 lb round bales. Is this the lifting capacity I can expect from this tractor? Thanks in advance.
Doug Stockman
Aces
08-02-2003 06:23:31
 Re: 460U front loader lift capacity in reply to Doug Stockman, 08-02-2003 04:20:24
Doug It should lift 1500 or more but not only the pump but the loader must be able to dow it as well. My home town had a 460U and loaded sand with for winter streets.
