MD purchase price, condition, tires
adam smith
08-02-2003 11:27:48
Hello! I am going to open by apologizing for any ignorance I may express, the length of my post, and any repeated information that I may be asking for. I am new into tractors, but was turned onto this site by a friend and have enjoyed reading through the archives for a couple of hours!
Anyway, I am looking for a haying tractor. I have 45 acres in hay for which I will need to pull the necessary equipment (small baler) as well as other odds and ends that are involvled with the rest of the property. I have found a 1949 MD that appears to be in good shape. It has a Dual (sp?) front end loader. I am told that the hydrolics have been converted to a "live" pump by mounting a drive on the outside of the frame on the left side. Both the three point and the loader work under a load. The tractor started easily and warmed up fast (it was 80 degrees though.) Gears seemed to work fine, no apparant leaking of oils, hydrolics, etc . . . Generator is supposed to have been gone through and a new battery put in. The lights work, heads are not cracked, some minor welding repair on bucket, but no signs of such on castings, frame, etc. . . Needs tires bad. They have tread, but are severly cracked. It has also been painted, be it poorly, as EVERYTHING appears to have been painted, hydrolic hoses, engine parts (the paint was then wiped off of the ID plates), three point eyelets, etc. . . There appeared to be hook ups for two hydrolic hoses running to the rear of the tractor, however, only one was in place. I was told that this was because the tractor only has a single phase pump and there was no use for two lines. But why then are there two hook ups?
This tractor is at a small town dealer(? a retired gentleman who seems to be at it more for a hobby than a business). The same friend who turned me on to this site says that the guy is one of the most knowledgeable in the state (Colorado). He is asking $3950, which he says is low because of the tires. It doesn't sound all that low to me, but as I said, I am new when it comes to tractors and most of the info I've found (including on this site) has shown sale prices $1000 or more lower, but none of them have been recent and none in this area. I feel that the MD has all I need and will serve my purpose, but AM wondering what will tires run me (approx), is it a steal/good/average/high price, and is there anything else I should look for or be aware of?
He also has 2 1942 M's that he is asking $2800 and $4600 for. They have no loader or no three point respectively, but tires are in better shape. I like the idea of the diesel better, but maybe I'm way off.
Thank you all for your time and information,
Adam Smith
Mead, CO
Fyrman 904
08-02-2003 21:46:44
 Re: MD purchase price, condition, tires in reply to adam smith, 08-02-2003 11:27:48
Adam, these guys are right, you'll be paying way too much through most any dealer. Your best bet is to find one through a private owner. Try the want-ads on this site, you can search for one in your own area that way. I live in South-West Iowa, I have 2 M's, a 47 and 48. I bought the 48 3 years ago, with a loader, cost me $1250. I got my 47 this year, with a loader, hay rake, and a really nice NH S68 baler for $2500. Alot of guys out there seem to think a new paint job is worth $500, but usually only cost them $30 in spray cans. Take your time, and look them over real good, and you'll find the right one. Greg
TimV
08-02-2003 17:21:33
Adam: You're correct in your assesment--this is at least $1000 more than the tractor is worth. While it would certainly do what you want it to, you can get a tractor of similar size and ability that is 15-20 years newer for about the same money. The MD's are somewhat more desireable to a collector, but as you're going to be working the tractor, not restoring it, I'd keep looking.
Van
08-02-2003 12:37:41
RUN ----- dont walk away from this guy, he is a crook
rustyfarmall
08-02-2003 11:44:21
The dealer is way too high on all of them.
