how to jack up the front end of a tri-cycle
bill
08-02-2003 12:53:06
today i was in the shop, looking at my H, wondering how in the world do i jack up the front end to get it off the ground....
so, how do i?????
I RIGHT I
08-03-2003 19:52:07
 Re: how to jack up the front end of a tri-cycle in reply to bill, 08-02-2003 12:53:06
What I did when painting my H and C was to use a 4 ft. length of 2in. sq. tubing,slide it between the wheels from front to back,put the backside on a jackstand and use a floor jack on the front.It worked alright for me.IRI.
BEL@IN
08-03-2003 10:00:22
If you do block under the frame rails be sure to block both sides equally. Only one side is very unstable. And do put it in gear with brakes set.
Bill L Md
08-03-2003 05:22:23
Bill, you need to jack the tractor up and put cribbing under the frame.Then lower the tractor down on the cribbing.
Mguy
08-02-2003 16:28:31
Lock both back brakes, put it in gear, jack it up under the frame rail.Mguy.
rustyfarmall
08-03-2003 04:08:28
 Re: Re: how to jack up the front end of a tri-cycl in reply to Mguy, 08-02-2003 16:28:31
I tried it that way once, it still wasn't stable enough that I could trust it.
bill
08-03-2003 03:59:56
i thought about that, but wasn't sure if being on "one side" of the tractor would make it unstable.
will try it.
thanks.
BEL @ IN
08-02-2003 14:26:00
If you just want to change a tire, run one wheel up on a 4 x 4 timber or even a 2 x 4.
