B front ends
squeakyzig
08-03-2003 09:00:08
We recently aquired a 1947 Farmall B with a narrow front end. My husband wants to put a wide front on this. Did any of the 1947 B's come factory with wide fronts? Will we need to make any modifications? What Farmall models might the front end interchange with?
Thanks for your help. We will probably be posting out here more often as the restore process proceeds.
CNKS
08-03-2003 17:29:54
 Re: B front ends in reply to squeakyzig, 08-03-2003 09:00:08
Rather than mess up an original tractor, why not just sell it and buy an A?
gene b
08-03-2003 15:51:11
They never came from the factory with a wide front but you can put one from an A. I have all the parts to make the change.
Aces
08-03-2003 09:19:13
The A's and B's same tractor but the A's had wide front and the B's nerrow front. Never made nerrow front for A never made wide for B you would have to change front casting on either tractor to change from ont to other.
Hugh MacKay
08-03-2003 10:11:09
 Re: Re: B front ends in reply to Aces, 08-03-2003 09:19:13
Aces: Even then what do you think? I doubt that the left front wheel will line up with the rear wheel on left. At any rate they would not be restoring something original.
Holly
08-04-2003 07:43:21
 Re: Re: Re: B front ends in reply to Hugh MacKay, 08-03-2003 10:11:09
Thanks folks! This is the information I was looking for. I really appreciate the help and comments.
Dave_D
08-06-2003 11:05:47
 Re: Re: Re: Re: B front ends in reply to Holly, 08-04-2003 07:43:21
I have seen a B with a farmall C wide front end. It looked quite good to me. I took some pictures, I will try to get them posted tonight. The B has 4 casting points that were not drilled out, but it appears they were planning on offering a wide front end, but never did. The down side is that wide C front ends are hard to find and if you do they are usually expensive.
squeakyzig
08-08-2003 12:02:14
 Re: Re: Re: Re: Re: B front ends in reply to Dave_D, 08-06-2003 11:05:47
Thanks for posting the pictures. It does look like the front end mounting may have been modified to accommodate the wide axle.
Dave_D
08-06-2003 21:39:41
See if this posts
Third Party Image
Dave_D
08-06-2003 21:35:59
Farmall C front on a B:
