fuel injecters on IH/MD
super Dave in M
08-03-2003 12:42:18
Hey there guys I was woundering if anyone had problems with their IH/MD (1951) where it would run on gas but you try to switch it to diesel there it would just quit. I found out yesterday one thing it was not the fuel pump. Today I pulled one of the injectors out and started the tractor up I wanted to see if fuel got though the injector NOPE BIG NEG. I was woundering if any body could Good advice I what to do and Thank you Chuck's repair for helping me yesterday. Thanks Guys for taking time to help!!! Dave in SW MN
brianh
08-04-2003 06:12:55
 Re: fuel injecters on IH/MD in reply to super Dave in MN, 08-03-2003 12:42:18
Take off the side cover of the pump and confirm that the governor linkage is moving as you move the throttle lever on the side of the pump. Often the governor linkage sticks -- a little WD-40 and gentle working back and forth will free it up, if that's what it is. Brian
Eric
08-03-2003 18:26:45
Hey Dave,
where in mn are u i also live in mn and maybe able to stop by and see if i can figure it out might me a minor to a major problem also are u intrested in selling it or know of any md's for sale around u i have over a dozen gas start diesels and really like them eric
Super Dave
08-03-2003 18:37:35
 Re: Re: fuel injecters on IH/MD in reply to Eric, 08-03-2003 18:26:45
Eric: I am in Adrian Mn area how about you???
Eric
08-04-2003 18:49:10
 Re: Re: Re: fuel injecters on IH/MD in reply to Super Dave , 08-03-2003 18:37:35
from the twin cities but get your way quite often u still havin trouble with the old girl dave?
Roger
08-03-2003 18:26:08
Dave, It depends on how much money you want to spend and what you expect in the end from your MD. If you have no experence with injectors and injector pumps I wouldn't advise working on it yourself. You can take out the injectors and get them tested and also the injector pump. If you are in Soutwest Minnesota, Central Fuel Injector Service is in Esterville, IA and where I had mine rebuilt at DK Diesel in Watertown, SD. Roger
Haas
08-03-2003 14:12:18
You did not say if you advanced the diesel speed control lever. Unless you advance that to give it some throttle, it is in shut off mode and you will get nothing to the injectors.
Jon
08-03-2003 13:50:01
The pump is very comlicated, lots of valves, ports, separate pumps, etc... I would rule it out yet. Possibly there is something wrong with the distributor block?
Farmaller
08-03-2003 13:20:22
How did this problem occur, was it running before this or has it been sitting awhile?
super Dave
08-03-2003 15:51:11
 Re: Re: fuel injecters on IH/MD in reply to Farmaller, 08-03-2003 13:20:22
Farmaller:
Well it it use to work OK but, sometimes it would convert to diesel but sometimes it would not then one it did convert so we park it that was 1.5 years ago I'm finally trying to tackle the problem we were having Super Dave in MN
Farmaller
08-03-2003 16:02:43
 Re: Re: Re: fuel injecters on IH/MD in reply to super Dave, 08-03-2003 15:51:11
I am pretty sure that the plunger is stuck. If you run it on gas and open bleeder on a injector then open diesel up it should have diesel coming through. Every one I have worked on that had been sitting a while had the plunger stuck. You have to take the pump off to get it unstuck. What you need is the I&T shop manual IH-8. It's not that complicated if you read the manual. These pumps are easy to work on because they are pretty simple. I go to my local hardware store to replace the seals and o'rings.
Super Dave in MN
08-03-2003 18:02:35
 Re: Re: Re: Re: fuel injecters on IH/MD in reply to Farmaller, 08-03-2003 16:02:43
Farmaller: I do have fuel going To the injectors but, I don't have going through the injectors (I can get fuel to bleed out of the side of the injectors. Also I was woundering is the a primary and a secondary pump the this fuel system. Thanks much Super Dave
Farmaller
08-03-2003 18:52:26
 Re: Re: Re: Re: Re: fuel injecters on IH/MD in reply to Super Dave in MN, 08-03-2003 18:02:35
Primary is where fuel go in from fuel filters, secondary is inside called plunger. When you run on gas and unhook throttle at pump, pull all the way back and see if engine smokes, if not could injectors are froze, which you can clean. Could be you dont have enough pressure to open them. I also had one that wouldn,t run because the starting valves wouldn,t close and therefore no compression. You can take valve cover off and make sure the rod that pushes starting valves down is releasing all the way. Other than this you might have to pull the head. I am giving you advise on my dealings with gas start/diesels I do not callmyself an expert but I can usually figure out how to get them to run.
Super Dave
08-03-2003 19:27:28
 Re: Re: Re: Re: Re: Re: fuel injecters on IH/MD in reply to Farmaller, 08-03-2003 18:52:26
Farmaller:Thank you for taking time to help me out I did try a couple things you wrote to me. Like I Took off the valve cover to make sure that the starting valves were not stuck (and they were not) and I asked another guy (chuck's repair) if 61 psi was enough and he said yes that it was plenty of pressure. But one thing I didn't try was cleaning them I did on the other hand take one out completely and hook it on to it's fuel advanced the throtle and started it on gas and let it warm up and try to convert it over and at no point do put fuel out (except a few LITTLE drops. I do wounder if all the injectors are dirty and do you know how to clean them If so your help is very much apprecatied. Thanks Super Dave
Farmaller
08-04-2003 20:00:42
 Re: Re: Re: Re: Re: Re: Re: fuel injecters on IH/ in reply to Super Dave, 08-03-2003 19:27:28
Take them out and soak them in a good cleaning solution for a couple of hours. then take them apart to clean each piece just make sure you do one at a time and remimber how they go back together. I have done this a couple of times and never had any problems.
Farmaller
08-03-2003 13:19:16
